Topic: music cutting off. mac. big sur
dceeceePRO InfinityMember since 2018
is anyone one else experience this when im mixing maybe after 5 mins. one of the levels goes completely missing and when i cross over there is no sound or even if i push the cue or hot buttons even without crossing over it cuts the music "in and out" and when i look on the screen there is no input for that channel i have to restart for it to re appear again
geposted Thu 26 Nov 20 @ 4:30 pm
Big Sur might not be compatible yet, but its being tested.
Most of all your hardware might not be compatible. Check with the brands website, and for example Pioneer, Denon etc is recommending to wait.
geposted Thu 26 Nov 20 @ 8:06 pm
thanks. but the samething happens even when im not using a controller and using only my comuter. about 5 mins in it does that
geposted Fri 27 Nov 20 @ 1:02 am
....and your computer is running Big Sur.
"Big Sur might not be compatible yet, but its being tested."
geposted Fri 27 Nov 20 @ 9:02 am
Have you had issues saving POI changes and edits? For example I create saved loops and change hot cue points and when I shut down and open VDJ later, all changes gone and reverted back to original settings.
geposted Wed 02 Dec 20 @ 10:21 pm
not sure im blessed to have both windows mac installed on my mac. i just revert to windows when i want to use vdj now until it sorts its self out
geposted Sun 20 Dec 20 @ 3:27 am
