Hello,
I try to make a COLOR FX on/off button for DDJ-400. I'd like to do it for Master CUE button.
I have some problem wit writting script. Propably I do not understand all tips :/ So I pleas help me guys.
Actualy my skrip look like this:
<map value="PFL_MASTER" action="deck 1 filter_activate on & deck 2 filter_activate on" />
When I put the CUE button, effect is on. But when I put CUE again, nothing gonna happend. What I need to add to this code line?
geposted Mon 30 Nov 20 @ 10:05 pm
add nothing remove the "on" they switch on the effect at all every press
action="deck 1 filter_activate & deck 2 filter_activate"
this way this is a toggle first press activates the effect second switch it off
you may also use
action="deck all filter_activate"
to make it work whatever the number of decks is
you may also use
geposted Mon 30 Nov 20 @ 10:26 pm
Thank you very much! It works perfect!
geposted Tue 01 Dec 20 @ 6:30 pm
