Whenever I press the "write tag" button on the tag editor, it adds a seemingly random REPLAYGAIN_TRACK_GAIN tag or to the file (if it already has one, mp3tag shows it as either x.xxx db//x.xxx db in the tag panel, or two separate "REPLAYGAIN_TRACK_GAIN" tag and value pairs in the extended tags menu). I though maybe this had something to do with the auto gain but it doesn't match the value. Is this a bug? Foobar2000 seems to use the first one, that I set myself, but idk if it causes any problems somewhere
geposted Fri 18 Dec 20 @ 12:53 am
