What value JogSensitivityScratch should there be to make it look like real vinyl.
geposted Mon 21 Dec 20 @ 12:26 pm
Default is usually best..
Any limitation is probably more due to a midi controller not being real vinyl ...
If its a low end entry midi controller it might even be a bit "laggy"..
What you can try is to set touchWheelBackspin to "no" to get a bit "tighter" respons, so that the software can "assume" you move forwards when midi is dead silent
And even touchWheelForwardspin to "no"
geposted Mon 21 Dec 20 @ 12:40 pm
More detailed. The amplitude of the distance of the wheel movement to match the movement of the vinyl. For example, in VDJ, when the value of jogsensitivityscratch=1, the signal goes further than in Serato, with the same movement of the controller wheel. Who has the distance of the real vinyl?
geposted Mon 21 Dec 20 @ 1:30 pm
