Topic: Filter behavior
Hello
I find the filter a bit annoying that if I rotate it first not much audible happens and then all the sudden all the sound is filtered away within few degrees of rotation. This works much better on my denon prime 2. Is there a way to change the filter curve or other parameters to make the filter more usable?
I think the center frequency might be a bit high and causes that effect of making barely audible changes and when the frequency is near a useful range you already used quite a bit of range of the knob.
Many thanks!
geposted Mon 21 Dec 20 @ 3:47 pm
