Pioneer ddj rb. The problem with channel switching in the headphones.The active channel is playing, but I can't switch to the second one. When you press pfl, nothing happens, when you press the master becomes louder. How to fix it?
geposted Fri 25 Dec 20 @ 10:25 am
Check your sound config to make sure the channels are set up properly.
https://www.virtualdj.com/manuals/hardware/pioneer/ddjrb/setup.html
geposted Fri 25 Dec 20 @ 10:34 am
