when i hit echo out all audio would cut out . the music is play still and led s still lite but just no effect working or sound. ns7ii .. all else seems good . uninstalled and install serveral times no luck.thanks !
geposted Sun 03 Jan 21 @ 3:50 pm
tested here with the same build, and I'm not seeing it [also tested out of sample rate tracks] give us your effect settings (look at the fx gui)
geposted Sun 03 Jan 21 @ 4:21 pm
It's working ok for me - same build
geposted Sun 03 Jan 21 @ 4:27 pm
With RZX I noticed a problem with the Color FX Reverb, when the channel knob is moved the effect seems to mute, and then it works when you leave the knob. Anyone have the same problem?
geposted Sun 03 Jan 21 @ 5:02 pm
