Topic: DAC-2 support
JackoldHome userMember since 2021
Is there any way to get the old PCDJ DAC-2 controller to work with VDJ2021?
I have it working on 64-bit windows 10 running VDJ 7, works fine using the 'serial to usb' convertor method described in older posts, but in VDJ2021 there is no option to select serial devices!
Any help would be appreciated :)
geposted Mon 04 Jan 21 @ 12:38 pm
I'd like to see the DAC-2 added to the controllers list as well.... having a simple controller option for a second system or for Karaoke would be great! Plus, it's better for the environment to not have my DAK-2 end up in the landfill.
geposted Mon 04 Jan 21 @ 6:11 pm
Hello, Is there any update / information on this? I actually prefer the DAC-2 over today's controller.
geposted Wed 17 Nov 21 @ 3:03 pm
