OK so I have a bunch of preset texts that I want to trigger from different custom buttons.
I can toggle the text effect on/off by using video_fx 'text' but how do I tell it to show a specific preset?
I can't find any examples.
geposted Wed 06 Jan 21 @ 11:12 am
Dont think that part of the effect is available as button or slider.. .
You can easily query any effect and expose whats available by setting a custom button with name query and using the actions below using "text" effect as example:
get_effect_button_count "text"
get_effect_slider_count "text"
- and -
get_effect_button_name "text" 1
get_effect_button_name "text" 2
get_effect_slider_name "text" 1
What you can do (for now) is putting the texts you want to use directly in the custom button (and each custom button can have many "presets" if you use the [ + ] feature next to button name in the button editor, creating a drop down to select...)
effect_string 'text' 2 "Hello World!"
- and -
geposted Wed 06 Jan 21 @ 12:42 pm
Would indeed make sense though, will add
effect_string 'text' 3 "presetname"
geposted Wed 06 Jan 21 @ 1:02 pm
Thanks Adion. If only Denon DJ responded to things as quickly :-(
geposted Wed 06 Jan 21 @ 5:02 pm
Tried that - doesn't do anything. I also tried get_effect_string 'text' 2 "Hello World!" as effect_string is not listed as an option, but that doesn't do anything either.
geposted Wed 06 Jan 21 @ 5:24 pm
Works fine here. You are using text on the decks right? Otherwise you'll have to add "deck master" in the front
geposted Wed 06 Jan 21 @ 5:55 pm
OK adding deck master works (I'm using text from the master video fx).
Ideally though the button should turn the effect on and display the text, and turn off when clicked again. I'll work that out.
[edit] finally getting somewhere now. I can make two buttons, each with different text, work - but pressing either one makes both light up.
1) deck master effect_active 'text' & deck master effect_string 'text' 2 "DOGS"
2) deck master effect_active 'text' & deck master effect_string 'text' 2 "CATS"
How do I prevent both lighting when I press one button?
VDJ is great, but sometimes things that should be so simple get really complex.
geposted Wed 06 Jan 21 @ 6:43 pm
Just swap the actions
deck master effect_string 'text' 2 "CATS" & effect_active 'text'
deck master effect_string 'text' 2 "DOGS" & effect_active 'text'
geposted Wed 06 Jan 21 @ 7:29 pm
Thanks, that's better - but the button still stays lit, regardless of on or off.
Hopefully Adion won't take too long to add the ability to run a text preset, so we have a choice of font, colour, position and so on.
geposted Wed 06 Jan 21 @ 7:34 pm
deck master effect_string 'text' 2 "CATS" && effect_active 'text'
deck master effect_string 'text' 2 "DOGS" && effect_active 'text'
geposted Wed 06 Jan 21 @ 7:56 pm
preset has been said it's coming, colour seems reasonable but doesn't exist yet [I think]
position is a very interesting idea; [which expands to anything that has a position box]
how would I do it; 4 dials - top left corner 2 dials, 1 x , 1 y - bottom right corner 2 dials [same again] but I'm imagining the most basic way how existing script works
geposted Wed 06 Jan 21 @ 8:30 pm
Just put the part that is on/off first in the script, for simplicity .. . that will display the button as lit only when on
deck master effect_active 'text' & effect_string 'text' 2 "Hello World !"
geposted Wed 06 Jan 21 @ 8:40 pm
Nicotux wrote :
Thanks Nicotux, that did it :-)
Looking forward now to maybe having a pad page that can trigger different words/phrases.
geposted Wed 06 Jan 21 @ 9:02 pm
Thanks Atomix for adding the ability to trigger saved text presets from custom buttons/pads :-)
geposted Fri 15 Jan 21 @ 3:07 pm
