I use the scheduler to automate playlists but the time settings have some issues, I can enter time in 24 hour format but if I launch a schedule during the evening that has an action starting at 9:00 am the following day it will trigger incorrectly. It seems that the clock setting does not know the difference between 00:00 and 12:00 ? or 13:00 and 1:00 etc. Please can you fix the time settings so that the 24 hour settings work correctly or add AM and PM setting. Also if you enter seconds into the time, these are diplayed in the schedule but as soon as you press start and the schedule is armed the seconds disappear.
geposted Wed 20 Jan 21 @ 11:59 pm
Having searched the forum it seems that the scheduler can only operate in 12 hour mode, you should look at adding more features to this with a schedule linked to a calendar, this would attract more people to use VDJ as broadcasting software.
geposted Sat 06 Feb 21 @ 11:23 pm
