Hello,
I am trying to map the parameters buttons (https://i0.wp.com/thedjpro.co/wp-content/uploads/2018/07/parameter-buttons-shift.png?resize=374%2C224&ssl=1) and use them to beat jump. The challenge is to get them to jump the number of bits that is currently used to set loops (1, 2, 4, 8...). I am hoping to use those buttons instead of using the pad to get to the beat jump page.
Any idea?
Thanks
Any idea?
Thanks
geposted Sat 23 Jan 21 @ 3:57 pm
I think I figured it out.
Parameter - button:
loop ? loop_move -100% :
loop_select 0.03125 ? goto -0.03125 :
loop_select 0.0625 ? goto -0.0625 :
loop_select 0.125 ? goto -0.125 :
loop_select 0.25 ? goto -0.25 :
loop_select 0.5 ? goto -0.5 :
loop_select 1 ? goto -1 :
loop_select 2 ? goto -2 :
loop_select 4 ? goto -4 :
loop_select 8 ? goto -8 :
loop_select 16 ? goto -16 :
loop_select 32 ? goto -32 :
goto -64
Parameter + button:
loop ? loop_move +100% :
loop_select 0.03125 ? goto +0.03125 :
loop_select 0.0625 ? goto +0.0625 :
loop_select 0.125 ? goto +0.125 :
loop_select 0.25 ? goto +0.25 :
loop_select 0.5 ? goto +0.5 :
loop_select 1 ? goto +1 :
loop_select 2 ? goto +2 :
loop_select 4 ? goto +4 :
loop_select 8 ? goto +8 :
loop_select 16 ? goto +16 :
loop_select 32 ? goto +32 :
goto +64
Parameter - button:
goto -64
Parameter + button:
goto +64
geposted Sat 23 Jan 21 @ 6:44 pm
