Hello everybody! I use macros "var '$shift' ? select : get decks 2 ? select : pfl" for Pfl (cue) buttons on my ddj rr. So, differents between standart Cue is - when i press cue on left channel while right channel cue is active - it switches active channel - turns off right channel and turns on left channel in the same time just with one press. I'd like that way, but sometimes i need to turn off both channel, so i need to modify my macros in a such way, that whith a long press on any channel - that channel turns off. How to do that?
geposted Tue 26 Jan 21 @ 12:40 pm
var '$shift' ? select : get_decks 2 ? select : holding ? deck all pfl off : pfl
I'm not sure what your get_decks thing is about but what you used in your post isn't a script
[its get_decks X, not get decks]
geposted Tue 26 Jan 21 @ 12:53 pm
Nope, holding cue does nothing anyway(
geposted Tue 26 Jan 21 @ 1:11 pm
On which controller are you trying the above ? There may be some firmware limitation behind the PFL buttons on some controllers.
geposted Tue 26 Jan 21 @ 1:14 pm
Pioneer Ddj rr
geposted Tue 26 Jan 21 @ 1:37 pm
Should work. At least works here when called from another 4 decks controller.
Can you try to see if it works without the decks query.. so .. just ... holding ? deck all pfl off : pfl
geposted Tue 26 Jan 21 @ 3:27 pm
Doesn't work at all. By the way, default settings for Cue button is just "pfl". And it works the same as usually works on any pioneer mixer. You can turn off/on any channel, or can listen them simultaneously. Thats not usable for me, because in 99% i want to listen just one channel, and in default settings i need to push buttons twice every time (to turn off previous channel and turn on next one). so script "var '$shift' ? select : get decks 2 ? select : pfl" suits me in 99%, but sometimes i need to turn off both channel. THats why i'd like to add possibility to turn off channel by long pressing
geposted Wed 27 Jan 21 @ 4:28 am
just because it should work the other way ^^
holding ? pfl off : deck all pfl off & pfl
but this is wrong as second pfl will apply both to same deck
holding ? pfl off : deck all & param_equal `get_deck` `get_defaultdeck` ? pfl : pfl off
but button does not lit
so
pfl & holding ? pfl off : deck all & param_equal `get_deck` `get_defaultdeck` ? nothing : pfl off
or better:
pfl & pfl 0% ? nothing : holding ? nothing : deck all & param_equal `get_deck` `get_defaultdeck` ? nothing : pfl off
short click : pfl off toggles pfl only for the actiondeck switches ll other off
when pfl is on : switches pfl off not altering the other
long press : toggles pfl on or off not altering the other
so
or better:
geposted Wed 27 Jan 21 @ 12:08 pm
so
or better:
so
or better:
Unfortunately both doesn't work correct. With short press i just have short blink on the cue button, long press do nothing
geposted Wed 27 Jan 21 @ 12:57 pm
If djdad's script does not work as expected, (mute everything when long press)
there is a limitation with DDJ-RR controller
other script wont work :\
geposted Wed 27 Jan 21 @ 1:16 pm
Sad story. But thanks for help anyway.
geposted Wed 27 Jan 21 @ 1:37 pm
Sorry, guys, was my mistake. Easy macros "holding ? pfl : var '$shift' ? select : get decks 2 ? select : pfl" - works well.
Thanks again for helping
geposted Wed 27 Jan 21 @ 1:52 pm
