Hi,
Every time I play with ColorFX with my reloop Elite, all colorfx ("cut, distorsion, echo, flanger, filter, noise, loop roll, pitch, reverb, spiral and vocals") work at the begining then after a few minutes playing with tem or changing them only "filter, noise, loop roll, pitch, vocals" are working, other fx don't work even when selected and enabled ... Any idea?
Same results with build 6242 & 6263...
geposted Wed 27 Jan 21 @ 4:49 pm
Problem is still here with version 6294 of VDJ: all color Fx works at the begining then after loading a new track on a deck "reverb, distorsion, Echo, flanger, cuts" stop working on any deck...
geposted Fri 12 Feb 21 @ 4:54 pm
Finally I found what is causing the issue:
As soon as I put FxProcessing to post, those ColorFx "reverb, distorsion, Echo, flanger, cuts" stop working instantly, other colorFx are still working without problem...
And as soon as I put FxProcessing to Pre then all color fxs work fine again instantly.
Could you solve that?
geposted Fri 12 Mar 21 @ 12:15 pm
What does your audio config look like?
geposted Fri 12 Mar 21 @ 12:19 pm
It looks like exactly like the pic "Reloop ELITE– Audio Setup Timecode Inputs" in your manual setup for the pro Elite, page:
https://www.virtualdj.com/manuals/hardware/reloop/elite/advanced.html
geposted Fri 12 Mar 21 @ 12:33 pm
We are investigating your report, but we currently dont have the Elite mixer, so need your help.
When post-fader setting is enabled, can you apply Deck Software Effects from Skin and also work as Post-fader ?
geposted Sat 13 Mar 21 @ 7:36 am
Hi, thanks for investigating.
I'm not sure I understand your question, do you mean if I can engage "On" an software fx from the skin?
Yes I can engage any software fx from the skin and it works perfectly in post or pre fader.
On a side note when trying stem fx yesterday I saw stem fx are pre fader and when bypassing stem fx, the fx returned to post fx for the global track, is it normal?
geposted Sat 13 Mar 21 @ 12:33 pm
