DOES ANYONE HAVE PROBLEMS WITH BROADCASTING?
geposted Fri 29 Jan 21 @ 6:48 pm
If you mean the "audio" broadcast option in VirtualDJ its a personal user to user broadcast where you are the radio "server". So for it to work, listeners needs to be able to connect to your computer.
You probably need to open port in your firewall/router. See here:
https://www.virtualdj.com/wiki/open-port-for-direct-broadcast.html
And if out of luck, broadcasting TO a radio server instead , is much easier to make work.
And plenty of options, see here for a few: https://www.virtualdj.com/wiki/broadcast-to-a-radio.html
geposted Fri 29 Jan 21 @ 7:27 pm
Some currently broadcasting users right now below, so the broadcast itself works, but often needs a little fix your end for users to be able to hear you :)
http://www.virtualdj.com/user/jeanmicheltfreefr/live.html
http://www.virtualdj.com/user/user9351816/live.html
http://www.virtualdj.com/user/scott798/live.html
http://www.virtualdj.com/user/pharaohonthebeat/live.html
http://www.virtualdj.com/user/galaktika12/live.html
geposted Fri 29 Jan 21 @ 7:32 pm
Do you know where I can get the settings for the VDJ broadcast option?
geposted Sat 25 Sep 21 @ 8:26 pm
In the software click on config and select broadcast
geposted Sat 25 Sep 21 @ 8:39 pm
Iol I know that, I was referring to what you fill in i.e.url, name, source etc - mine's not filled in.
geposted Sun 26 Sep 21 @ 1:37 pm
Doesn't work me. I tried the broadcast option just for fun. I opened Port 8000. https://portchecker.co/ said I was good to go. I opened my broadcast tab and it forwarded me to:
http://www.virtualdj.com/user/very_unique_dj_name/live.html
That page brings up a white box with a VDJ record and says: OFF AIR
This is different message than when I had port 8000 closed.
geposted Wed 29 Sep 21 @ 11:50 pm
I get the same thing any help would be greatly appreciated
geposted Sat 04 Dec 21 @ 8:05 am
I had the same problem as well. After a couple hours of trial and error trying to configure my firewall and router to work with VDJ, I finally got it working. It ended up being a router setting that was preventing it from broadcasting even after setting up the port forwarding, I also had to unselect internet NAT redirection in my filters. I hope this helps out other fellow DJs that are running into this problem.
geposted Fri 04 Mar 22 @ 7:19 am
the solution is to set direct port in vdj to port 80 and forwarding ports to 8000 both firewall and modem
geposted Sun 05 Jan 25 @ 4:00 pm
Can you do a step by step on NAT FILTER, please?
quote=DJ Bmartin]I had the same problem as well. After a couple hours of trial and error trying to configure my firewall and router to work with VDJ, I finally got it working. It ended up being a router setting that was preventing it from broadcasting even after setting up the port forwarding, I also had to unselect internet NAT redirection in my filters. I hope this helps out other fellow DJs that are running into this problem.[/quote]
geposted Sun 30 Mar 25 @ 6:53 pm
Yes says OFF AIR.. ports are open and done all troubleshooting.
geposted Sun 30 Mar 25 @ 6:54 pm
Also having this problem. Port 8000 open. I've broadcast many times up until recently without problem. No settings have been changed.
It seems to register that I'm broadcasting but says 'off air' when you open the player. Strangely enough I had 1 person manage to connect and listen but others couldn't, including myself when testing from my mobile.
Support unhelpful, just sent me a generic link to a page about firewalls and ports.
If anyone has successfully solved this I'd love to know how
geposted Sat 31 May 25 @ 8:30 pm
Further to my above message, I've discovered I can connect when using mobile data instead of my home wifi and if connected to wifi I can only connect using a VPN. I can only assume that certain ISPs are blocking access possibly?
geposted Sat 31 May 25 @ 8:55 pm
you can't have a circular connection with most home ISPs
broadcasting on a port and receiving the broadcast on the same port.
When it's said, check on your phone it is meant check with your phone's data plan not using your phone with home wifi.
geposted Sat 31 May 25 @ 9:01 pm
