Hi,
I usually have Loop roll set as the color fx and the switch set to "filter eq" on the controller. I haven't used my controller in a couple month and just jumped back in and the current version when I turn the dial quickly the position of the software dial gets out of sync with the position with the physical dial.
This causes the loop roll to get stuck on, as even though my controller is back at the 12 O'Clock position, the software still things its at 3% or some other number depending on how fast I turn the dial to the 12 O'clock position.
Is there a workaround to this?
Many thanks
Dale
Many thanks
Dale
geposted Sun 31 Jan 21 @ 1:44 am
