Topic: Experiencing constant crashing and restarting
Hi:
MBP 2011 with OS X Yosemite I7 16GB RAM, AMD Radeon HD 6750M 1024 MB
2 SSD 5OO GB INTERNAL memories
VDJ 8.5 B6286 vers
experiencing constant program crashing and restarting when playing music videos.
Need Help ASAP
geposted Sun 31 Jan 21 @ 10:08 pm
Do you have any videos encoded with the AV1 codec?
geposted Mon 01 Feb 21 @ 3:55 am
NO
geposted Mon 01 Feb 21 @ 6:05 pm
Rather than just saying "no", it would be useful to tell Adion what format the videos which causes crashes are in (codec etc).
geposted Mon 01 Feb 21 @ 6:25 pm
As soon as i get home will give you the requested information, the funny thing is that been using the same video format for 5 years and never experienced this situation until installed VDJ new version....
geposted Mon 01 Feb 21 @ 7:40 pm
From reading people with similar problems it seems there is a previous VDJ 8.5 version 6257 that does not experience this problem.
Is there a way to uninstall this version and go back to a version that wont have this problem???
geposted Mon 01 Feb 21 @ 8:35 pm
all music files are mp4/MPEG-4 MOVIE, never experienced problems before
geposted Mon 01 Feb 21 @ 11:04 pm
tried disabling the Math engine but everytime i choose that option it goes back to CPU
geposted Mon 01 Feb 21 @ 11:19 pm
mborjarPRO InfinityMember since 2012
Hi Devora, do you have solution for your question?
I have same problem with V8.5 - 64 - b6294
I'm crazy because VDJ it closes when load in some video music, but I can't identify why it, and what kind of format will close the software, before playing it.
geposted Fri 12 Feb 21 @ 2:37 am
safevideomode option (no)
geposted Tue 06 Apr 21 @ 9:32 pm
I got around all these issues by just using the 32 bit version. I have had zero problems for months now. Love it! No, I dont have stems.. so what, I have a stable platform that is 100% reliable.
geposted Sat 10 Apr 21 @ 1:53 pm
Probably would be same just disabling stems in the 64-bit version then I guess...
(aka set mathEngine in the settings to disabled, if your computer cant handle it)
geposted Sat 10 Apr 21 @ 10:41 pm
