Proof on this video :
https://youtu.be/TotH8PAZpP4
Virtual audio drivers used :
https://github.com/ExistentialAudio/BlackHole
Blackhole 32 bits, virtual audio driversBetween :
apple music -> REW RTA measurement
VLC -> REW RTA measurement
Rekordbox-> REW RTA measurement
VDJ 8.5 6677 -> VLC -> REW RTA measurement
VIRTUAL 8.5 (V6677) DJ :
SRC 44100 to 48000 is only -63 dB THD+N : With 44100 1000Hz file, 16 bits or 24 bits
vs
Apple music app :
SRC 44100 to 48000 is -97 THD+N : With 44100 1000Hz file, 16 bits
SRC 44100 to 48000 is -130 THD+N : With 44100 1000Hz file, 24 bits
VLC (OSX) effects off :
Rekordbox 6 :
SRC 44100 to 48000 is -92 THD+N : With 44100 1000Hz file, 16 bits
SRC 44100 to 48000 is -92 THD+N : With 44100 1000Hz file, 24 bits
vs
Apple music app :
Rekordbox 6 :
geposted Mon 04 Oct 21 @ 12:56 am
          Not sure why you get those results.
I still get -90dB THD+N
samplerate: Automatic (set by virtual loopback to 48000)
pitchquality: 4
scratchquality: 30
autogain: off
generated wav file: 16-bit 44.1khz 0dbFS 1000Hz sine, no dithering
pitchquality: 4
scratchquality: 30
autogain: off
       geposted Mon 04 Oct 21 @ 7:30 am
          Hi Addion,
I've found de problem :
The default value on VDJ mac version of :
ScratchFilterQuality (and not ScratchQuality)
Was at 8 (to low ) and i've to change it at 30 ?
With 8 quality of SRC doesn"t work..... a lot of user use 48000 samplerats... by default you should set SRC settings at Pitch 4 and Scratch to 30 (Pitch 2 and scratchquality at 8 give -40/ -50 THD + N with 44100 files to 48000)
Even with Pitch 4 and Sq at 30, only 91 THD-N with other app reach 97 and 129 with 24 bits files...
please set by default higher quality SRC standard without the need to hack option wioth two settings....
The default settings give -40 -50 THD+N for user that use 48000 samplerates with a lot of controller midi audio that are fixes at 48000.. it's not enough.
And change the engine read/file file to 24 bits , the VDJ internal engine is 32 bits.....
geposted Mon 04 Oct 21 @ 8:33 am
          Checked on mac too
Can you check the tool tip of the gain slider to make sure it's not adding any gain?
Edit: and you checked scratchQuality setting as well?
geposted Mon 04 Oct 21 @ 8:51 am
          i've answered : see edited post before within you answered me:)
The default SRC quality settings are to low (2 and 8) and far from competitors.
When we install VDJ, the. default should be (Pitch 4 and Scratchfilterquality 30 )
It's the actual standard of SRC THD+N of other music player and DJ software
have a nice day
have a nice day
geposted Mon 04 Oct 21 @ 9:01 am
