hello there is a possibility to change the original performance skin
That you have a 3 band eq of color or an rgb color that is the same on deck a as deck b.
Because I tried to work with the skin modifier, but source code isn't really a thing
geposted Wed 03 Feb 21 @ 9:28 pm
Edit the skin, and look for <scratchwave>
colorVocal colorInstru colorBeat is the colors of the "3 band" waveform ;-)
Add those within the scratchwave elements to set custom colors
<scratchwave deck="1" orientation="horizontal" color="" color2=""
colorVocal="" colorInstru="" colorBeat=""
colorNoVocal="" colorNoInstru="" colorNoBeat="" >
geposted Wed 03 Feb 21 @ 11:11 pm
