I have 2 external drives; both are set to letter "E". can interchange these
drives between 2 laptops,, no problem.
New laptop; drive letter changes to "d".
Go through steps to change it back, but once the
\system is turned off and later restarted; the drive changes back to "D"
Anyone know how to make sure it stays as "E"?
geposted Mon 08 Feb 21 @ 5:51 pm
With such "low" letters I don't think you can make sure an external is using always the same letter.
If I were you and I wanted to make sure that my external is using always the same letter I would assign a "higher" letter, from J onwards (personally I use Q, but that's just me)
As for your current problem a possible reason may be if your laptop has a card reader.
In that case it's possible that during system initialization the letter is E is occupied by the card reader when the OS enumerates the drives and "disconnects" later if there's no card in it.
There may be other reasons too, but one thing is certain: Letter "E" is occupied by something else during drive enumeration.
geposted Mon 08 Feb 21 @ 7:01 pm
I can change the letters but then it will not be read in VDJ.
Is there a way to change the drive letter and have VDJ be able to read it?
geposted Tue 09 Feb 21 @ 5:53 pm
VDJ doesn't care which drive letters you use
geposted Tue 09 Feb 21 @ 5:59 pm
When the letter changed from E to D, VDJ would not read the drive.
geposted Tue 09 Feb 21 @ 6:09 pm
Have you "hidden" any drives in the VDJ settings previously?
Worth a check.
"ignoreDrives" should be blank
Worth a check.
geposted Tue 09 Feb 21 @ 6:15 pm
ignore drives show "0".
Really strange as it only changes on the new laptop.
geposted Tue 09 Feb 21 @ 6:34 pm
Try shutting down VDJ, rename your settings.xml file then restart to create a new one.
Might just be a gremlin.
geposted Tue 09 Feb 21 @ 6:43 pm
I do not think it is VDJ related. Every time I plug in the backup drive: the system
changes it to "D". Then when I plug in the original drive it also is "D".
geposted Tue 09 Feb 21 @ 7:01 pm
SOLVED:
Could not get drive letter changed through disk management.
Had to use the cmd prompt. Now everything is okay.
Thanks all
Thanks all
geposted Tue 09 Feb 21 @ 8:41 pm
Excellent. Great news!
geposted Tue 09 Feb 21 @ 8:48 pm
