I am trying to be able to connect a line in source. I am able to connect it to my DDJ-SZ but the audio does not go into the software and cant be heard on recording or stream PLEASE HELP
geposted Thu 11 Feb 21 @ 12:19 am
To help a minimum infos are needed
i.e.: System, OS, VDJ version...
Audio config ( a screenshot of Settings/Audio may help)
Basically if line in is visible and usable by the OS:
in Audio settings select INPUT if not already
Add an input "line in x" entry in Audio and affect the linein to it
then enable it on a deck to test (may depend ion skin) in default:pro layout it's in panel left of jog (custom buttons, hotcues, loops, timecode & line in)
geposted Thu 11 Feb 21 @ 12:46 am
If you want the source to be heard by VirtualDJ (and record/broadcast) you probably want to enable the input to deck
https://www.virtualdj.com/manuals/virtualdj/settings/audiosetup/linein.html
geposted Thu 11 Feb 21 @ 1:26 pm
As for the Audio Setup in VirtualDJ, read this .. https://www.virtualdj.com/manuals/hardware/pioneer/ddjsz/dvs.html
and instead of timecode inputs, replace them with linein
Also dont forget to open the DDJ-SZ Utilities and set to Line(CD) or Phono, depending on the type of the Input.
geposted Thu 11 Feb 21 @ 6:40 pm
Thank you for your help here is my info
Virtual DJ 8.5 64
Pioneer DDJ-SZ Controller
Win 10 Home Version 1909 OS Build 1863.1316
Processor Intel I7-4700MQ CPU @ 2.40Ghz
Ram 8.00GB
geposted Fri 12 Feb 21 @ 11:02 pm
