Forum: VirtualDJ Plugins
Topic: Show Logo Plugin for Mac with M1 (Metal)
Hello everyone.
Just got a Mac mini with M1 and hell yeah, it seems that the mini beats my MacBook 2020 all the way...
Just found out that the Show Logo Plugin is not working well anymore..
With a clean install of VirtualDj i could not get it to run. I Airdropped my VDJ Version from the MacBook and see there, the Plugin is working again. So far so good...
Then I Updated VDJ today on the Mini and the Show Logo Plugin was gone...
Back with the MacBook App it worked again... Had a 2 hours Teststream and all good!
But, in the same moment I activate experimental use Metal in the Options and restart VDJ the Plugin is gone again. Deactivate use Metal, restart and the Plugin is there again.
So for now I have to choose between Show Logo or use Metal. The problem ist, i really need Show Logo Plugin for my Videooverlay.
So the question is, is there any other workaround or an update coming to the Plugin any time soon?
How do you handle this at the Moment?
geposted Sat 13 Feb 21 @ 1:50 am
What do you use it for that you can't do with the regular logo or the sampler?
geposted Sat 13 Feb 21 @ 7:56 am
a Overlay Frame around the video.. have to change it for every stream...
its an .png with transparent section in the middle.. i need it over the top of all and sampler, screencap, cams and stuff is only behind that layer..
geposted Sat 13 Feb 21 @ 2:52 pm
videoLogo setting will do that as well.
Just write 1.0 as videoLogoSize to make it full screen
geposted Sat 13 Feb 21 @ 4:11 pm
oh THANK you! that works well for me!
have a nice day.. :)
geposted Sat 13 Feb 21 @ 4:28 pm
