I know it may seem a bit silly to post the solution right away, but, anyway, here's the thing:
System specs:
-Windows 10 on:
-Dell Inspiron 15 7558 (8GB RAM);
-Samsung SSD (850 EVO, 480 GB...);
-No controller
I've never experienced such weird freezes before, and I immediately thought 'what systems VDJ depend on...?'
Turns out my 'explorer' process was also acting weird and freezing, whenever I clicked 'My Computer'.
So, I searched a bit, and a bit more, when finally got to this "delete some registry keys" thing.
Under:
\\HKEY_CURRENT_USER\\Software\\Classes\\Local Settings\\Software\\Microsoft\\Windows\\Shell
Delete all "BagMRU" and "Bags" (they say not to worry, because Windows rebuilds them upon restart, and so it is...)
I had literally hundreds of keys within "Bags". They're about all gone. And so is that freezing sh==...
In the end, VDJ wasn't freezing at all. It was Windows "Exploder"...or explorer...
Hope it helps someone, someday. Cheers!
System specs:
-Windows 10 on:
-No controller
Under:
geposted Mon 22 Feb 21 @ 2:36 am
Bags and BagMRU is where windows stores folder view settings in case someone wondered
not sure how this helped unless he had a large amount of folders
more info can be found here
https://www.ghacks.net/2014/06/09/remove-old-shellbag-entries-windows-privacy/
geposted Mon 22 Feb 21 @ 1:12 pm
I came across another situation like that. Same symptoms, different cause: it was an unresponsive cell phone connected to a PC/notebook. 🤦♂️
(Though it never happened during live events, because...precautions...)
geposted Wed 24 Feb 21 @ 11:44 pm
