Hi all,
Does anyone had already tested VDJ2021 on the new Mac mini with M1 chipset and 8go Ram ?
Does it works properly ?
I actually use a Dell Inspiron 5400 with i7 11th generation, 16go ram and 512go SSD.
I face some sound scratch while playing music. It appears randomly. Every 20-30 minutes.
There are no other software on it. All drivers are updated.
I think it is an insolvable latency problem (it doesn’t change anything when I change the latency of the ddj1000)
geposted Mon 22 Feb 21 @ 8:28 pm
VirtualDJ works on M1 yes.
Even built for M1 via the "universal binary" available running natively ARM
For the Dell you can check if its any background processes that checks / schedule things at intervals.
Been some user problems with stuff checking for updates, etc from Dell (and others) that interrupt low latency sound. https://www.dell.com/community/Laptops-General-Read-Only/Audio-and-Video-make-buzzing-noise-stuttering-every-15-minutes/td-p/5109045
As well as just needing updated drivers such as for example:
https://www.dell.com/community/Laptops-General-Read-Only/Audio-problem-plaguing-dell-laptops-Dell-Please-come-up-with/td-p/3734110
And generally this tool can be good to pinpoint what causes issues:
https://www.resplendence.com/latencymon
geposted Mon 22 Feb 21 @ 8:35 pm
