So just got the cdj 2000's and the S11 I'm assuming I can just plug those in and the drivers will download themselves , any advise would be great.
geposted Sun 28 Feb 21 @ 6:10 pm
The drivers wont download by themselves.
So you need to install yourself..... after that its all plug and play and good to go ;-)
https://www.pioneerdj.com/en-us/support/software/archive/cdj-2000/
https://www.virtualdj.com/manuals/hardware/pioneer/djms11/setup.html
Although "plug and play" with a footnote, a bit of correct wiring of audio and usb cables are required.
Can see here for some help on that: https://www.virtualdj.com/manuals/hardware/pioneer/clubsetup/index.html
geposted Sun 28 Feb 21 @ 6:30 pm
Thanks Rune ,always quick and on point with your answers. Your the best.
geposted Sun 28 Feb 21 @ 6:39 pm
no prob, and being a bit "advanced" the routing part, dont hesitate to ask if you run into something ;-)
geposted Sun 28 Feb 21 @ 9:57 pm
