if no deck is selected as cross left or right, crossfader full left or full right still let all decks being eared and locks video ( auto crossfade is disabled) even when video_crossfader_link is off
is_audible report decks as audible but video does not follow
if no deck is selected as cross, crossfader centered still let all decks being eared and video follows the correct selected / audible deck
geposted Tue 02 Mar 21 @ 9:44 pm
Works fine here...
Since I don't understand what exactly you report as a problem:
If a deck is not set as cross right or cross left then it's set as cross 'thru' which means that it's always audible no matter where crossfader is. And that's the normal and expected behavior.
So, I assume you report that in the above case (all decks are set to cross 'thru') automatic video crossfader doesn't work. Right ?
If that's what you're reporting, then it works fine for me.
It works by assuming that decks 1/3 are assigned on left and decks 2/4 on right side of video crossfader.
Also it DOES take into account if the deck is audible.
(No matter where audio crossfader is)
Also automatic video crossfader disables video crossfader link (that's also logical)
So, could you please explain a little better what you mean above ?
geposted Tue 02 Mar 21 @ 10:12 pm
Yes this is the expected behavior.
when all decks are 'thru' the "unused" crossfader acts as a video auto crossfader enable switch
full left ==> off
full right ==> off
whenever is_audible goes on or off
other position => auto video crossfader starts to work again (taking care of all 3 rightvideo leftvideo and is_audible
it DOES NOT take into account if the deck is audible when fully right or left
full left ==> off
full right ==> off
geposted Tue 02 Mar 21 @ 11:03 pm
Well, it works here.
Any chance you have any kind of repeat script running somewhere causing side effects ?
I know that you and a couple of other users go a little wild with them ! :P
geposted Wed 03 Mar 21 @ 6:55 am
No running script
but found the reason :
videoCrossfader Smart AND faderStartStop enabled
faderStart disabled
faderStartStop does not stop video because faderstart is not enabled
but prevent the smart video link to work
faderStart disabled
geposted Wed 03 Mar 21 @ 1:17 pm
