Reporting a possible VDJ issue produces bad behavior, 100 % of the time when recording a sample, with BOTH Stems and Traditional EQ set.
Either:
1) crashes 80% of the time (VDJ disappears and comes back, not recording the sample)
2) stops working 10%, (see pic below)
3) records sample w pops/clicks 7% (listen to uploaded sample)
the original sample: https://www.mediafire.com/file/6jqjx6eiwihwoux/Hold_Up_%252812%2529.vdjsample/file
re-record to MP3: https://www.mediafire.com/file/wnm1ua61h3l8y7n/hold_up_re-record_of_sample_w_pops.mp3/file
4) hangs VDJ 3% (blue circle and sends crash report to MS)
To reproduce this:
Step 0) (in final tests would start Latency MON to check for audio latency during the crash or recorded pops/clicks, ...... not necessary for VDJ to misbehave)
1) Create Loop, and play the loop (have only tested this with 64 beat Loop, deck 1)
2) Adjust (EZRmix) Beat Stems ( I only tested at approx 9 o'clock.)
3) Increase Traditional EQ Low ( I only tested at 2-3 o'clock)
4) Click the Record button on VDJ Pro Skin, ( shows as highlighted blue in left of the photo ...... the stopped working image above)
then VDJ will do one of the 4 possible ways to not record the sample well.
NOTE:
VDJ works and records the sample perfectly if :
1) neither Stems or EQs are on
2) if only Stems is on
3 if only EQ is on
Only misbehaves when BOTH Stems and EQ are on.
Below is Latency Mon running, during 2 attempts to record a sample, 1st it crashed , second created sample 12 above with pops/clicks
Let me know if you need additional info.
You may have some of crash reports recorded, I was connected to the net.
VDJ v8.5-64 b6334
CPU: AMD Ryzen 7 2700X Eight-Core Processor (3700 MHz)
Memory: 65487 MB
OS Version: Microsoft Windows 10 64-bit (Build 19041.572)
Graphics Card Vendor: NVIDIA Corporation
Graphics Card: GeForce GTX 1080 Ti/PCIe/SSE2
Either:
To reproduce this:
NOTE:
3 if only EQ is on
VDJ v8.5-64 b6334
Memory: 65487 MB
geposted Tue 02 Mar 21 @ 9:52 pm
UPDATE: repost of sound file links from above. (maybe needed link correction, since could not find the original upload that was uploaded to the file sharing service, maybe removed for dmca or just a glitch)
re-record to MP3: https://www.mediafire.com/file/gzzrgpack0u59xl/hold_up_re-record_of_sample_w_pops.mp3/file
geposted Wed 03 Mar 21 @ 1:31 am
