Topic: M1 Neural Engine
When you look at the new Mac specs, they will be something like
"Apple M1 chip with 8‑core CPU, 8‑core GPU, and 16‑core Neural Engine"
(that's for a MacBook Air)
Will VDJ then use the GPU or the Neural Engine for stems separation?
geposted Wed 03 Mar 21 @ 1:21 pm
The neural engine
Adion wrote :
The neural engine
Very modern indeed :)
Adion wrote :
The neural engine
How can I tell which 1 VDJ is using??
I'm not sure if there's a way to really know what it is using, but based on the speed it's calculating stems it has to be
