Hi bosses can some one help me do mapping for pitch play?
Thanks
Thanks
geposted Thu 04 Mar 21 @ 10:06 am
Just set a cue point
And use the Key Cue performance pads that comes with the software
geposted Thu 04 Mar 21 @ 11:55 am
OK thanks so much.
What about pad scratch?
geposted Fri 05 Mar 21 @ 12:23 pm
Same as above, but choose the Scratch pads
https://www.virtualdj.com/manuals/virtualdj/interface/decks/decksadvanced/pads.html#scratch
geposted Fri 05 Mar 21 @ 12:24 pm
Our studio has ddj sb3 and there is a pad called pad scratch when pressed it will scratch from the cue point till release.
I want to do some on my pc.
geposted Fri 05 Mar 21 @ 1:54 pm
Look above, select the Scratch performance pads.. ;-)
geposted Fri 05 Mar 21 @ 1:56 pm
Note that the DDJ-SB3 has a firmware (internal) Scratch Pad mode, and probably different than the VirtualDJ Scratch Pad page. See https://www.virtualdj.com/manuals/hardware/pioneer/ddjsb3/layout/pads.html
So, you can have something similar with any other controller , but may not have exactly the same functionality/behavior.
geposted Fri 05 Mar 21 @ 4:04 pm
OK thanks Bosses
geposted Sat 06 Mar 21 @ 2:30 pm
