As of the most recent Virtual DJ update, I have noticed that I am now unable to utilize the previously default "space" key to play a track from an unused deck while fading. I've tried looking at the forms and the closest response was from a 2017 unresolved form. I don't want to use "mix_now" because it automatically changes the BPM and seems to drag itself back to the other deck.
I am specifically trying to make the space bar play the second deck the moment the slider crosses to the other side.
It originally worked on my Mac, but for some reason when I downloaded the software onto my PC, this command wouldn't work.
Here is the link to the previous form having the same issue (or so it appears):
https://www.virtualdj.com/forums/216899/VirtualDJ_Technical_Support/Using_the_spacebar_to_start_a_song_in_opposite_deck.html
geposted Thu 04 Mar 21 @ 10:48 pm
