Topic: do i need a new lappy?
pseftPRO InfinityMember since 2009
I'm thinking of purchasing DDJ1000...
i have a 2011 MBP 17 inch.
2.4 ghz intel core i7
8 gb rams 1333mhz ddr3.
do i need a new MB or can i still run the 2011?
I'm looking at 4 Chanel mixers, any other controllers i should look at, let me know...
cheers
geposted Fri 05 Mar 21 @ 3:07 pm
Your new controller won't change anything.
I guess it depends if you want to use stems, they struggle on older hardware.
geposted Fri 05 Mar 21 @ 3:20 pm
thanks...
i knew there was going to be some problems... damn, that another 3k.... all up under 5k grrrr
geposted Fri 05 Mar 21 @ 3:26 pm
Should be ok to connect a controller.
And you can always get controller first, and if things are too slow, upgrade computer after
Its a 10 years old computer, so might be time ;-)
geposted Fri 05 Mar 21 @ 3:27 pm
iv been stuck with sierra for a while now... can update to new os, which sux!
looking at 2020 or 2021
geposted Fri 05 Mar 21 @ 3:35 pm
both are 13 inch
these 2 are my final descissions
Apple M1 Chip with 8‑Core CPU and 8‑Core GPU
256GB storage
this one is 2k AU bucks
or
2.0GHz Intel Core i5 Quad-Core Processor with Intel Iris Plus Graphics
512GB storage
3k
geposted Fri 05 Mar 21 @ 3:44 pm
Touch choice, both are nice ..hehe
If it was me, I'd go for the M1 processor.. a bit more "future proof" since mac is changing to M1
(and reviews for the M1 been great, performance wise.. )
geposted Fri 05 Mar 21 @ 4:13 pm
As much as I dislike MacOS you can't deny the M1 air is a very powerful machine for the money.
geposted Fri 05 Mar 21 @ 4:34 pm
The question is always what I want, clearly that the hardware from 10 years ago does not have the same performance as the current one. But if it works and you are satisfied ...
The current version VDJ runs on all my computers without any problems!
1.) MacBook pro (2008) 4GB RAM 256 SSD and 2TB HDD
2.) ASUS (2008) intel dual core 4GB Ram 256SSd and 2 TB HDD3
3.) Fujitsu LifeBook (2011) Intel i5 8 GB Ran 256 GB SSD 1 TB HDD
4.) AMD FX (tm) -6300 Six-Core (2016)
16 GB Ram 4 TB HDD GeForce GTX 1050 Ti
5.) the newest :) Mac Book Pro 2019 Intel i9 32 GB Ram 2 TB SSD
The question is always what I want!
All systems are running and I would have a life gig with everyone at any time.
But I also maintain my hardware.
Only software that I really need and maintenance every 6 months - means screwing it on, cleaning the fan and everything else.
never had a crash in live operation.
geposted Fri 05 Mar 21 @ 5:42 pm
i like the M1 as well.. 20 hrs battery time is great and stick wth the 500 gig HD
thanks guys
geposted Fri 05 Mar 21 @ 6:45 pm
