This might be a newbie question but is there a way to setup a cue point that will automaticly start a loop at the end of a song? THX!!!
geposted Fri 05 Mar 21 @ 6:53 pm
my turntable does normally play I'm asked for a code that talks about license
geposted Fri 05 Mar 21 @ 7:04 pm
You need a license for extended use with DJ gear connected.
Get your license here https://www.virtualdj.com/buy/
geposted Fri 05 Mar 21 @ 7:13 pm
You can do that.. set a cue point,. then open the "point" editor, and set it to action point, with the action loop 16 (or the number of beats you want to loop) https://www.virtualdj.com/manuals/virtualdj/editors/poieditor.html#actions
Alternatively just use the "saved loop" feature with a saved loop at end
https://www.virtualdj.com/manuals/virtualdj/interface/decks/decksadvanced/loops.html#savedloop
https://www.virtualdj.com/manuals/virtualdj/editors/poieditor.html#savedloops
geposted Fri 05 Mar 21 @ 7:24 pm
