Hi hope someone can help me when i broadcast to mixcloud my bitrate is showing as 96 kbps how do i force virtual dj to broadcast the audio at 320 kbps using the video broadcaster optio as it seems to be max 128 kbps on the high setting??
geposted Fri 05 Mar 21 @ 9:15 pm
was a recent update that set default higher for Mixcloud, so try that update first (not public yet)
Just download the installer and run it to update
https://www.virtualdj.com/download/pc/6334 (Windows)
https://www.virtualdj.com/download/mac/6334 (Windows)
Alternatively you can set your own broadcast settings.
In VirtualDJ setting options set broadcastVideoQualityCustom to the desired format:
videoResX x videoResY@videoKbps,audioKbps
(for example 1920x1080@6000,320)
Then set set broadcastVideoQuality to "custom".
geposted Fri 05 Mar 21 @ 10:05 pm
Thank you
geposted Fri 05 Mar 21 @ 11:50 pm
