Hi,
Is there a simple band pass filter add-on available for VDJ? I know the rollbpf and echobpf effects, would like to use a very simple band pass filter. (I know it can be achieved via combining HPF and LPF, just wonder if it is around as a separate effect.)
Cheers,
Cheers,
geposted Sun 07 Mar 21 @ 5:58 pm
VirtualDJ can use VST effects, so if the effects you find in Extensions in side the software isnt exactly how you wanted it, just try some VST effects instead...
There are 10.000s of available VST effects so chances are good one of them are to your likings ;-)
https://www.virtualdj.com/wiki/how-to-use-VST-effects.html
geposted Sun 07 Mar 21 @ 6:07 pm
Perfect, thank you very much!! :)
geposted Sun 07 Mar 21 @ 8:34 pm
