Topic: My mixing track bar isn't working
It was working before until I stopped working, Do I have to reinstall VirtualDJ? If you don't understand, it's that little bar where you switch "A" to "B"
geposted Mon 08 Mar 21 @ 8:01 am
I guess you mean the crossfader? In the mixer area where you select what side to hear?
Are you using a controller, or just in software?
Might just be wrong sound settings (not having master to correct output). And if you have a controller check A/B switches at the crossfader.
If its just in software, you can also try rename settings.xml in /documents/virtualdj/
And then start the software. That way you have default settings, in case you disabled the crossfader or set it to be thru or something else... to test :)
geposted Mon 08 Mar 21 @ 11:45 am
