As above, if a new post is raised with an error in the title it can't be changed as a Pro user.
geposted Mon 08 Mar 21 @ 12:26 pm
Might add something for that ;-)
geposted Mon 08 Mar 21 @ 12:30 pm
I assume that that the Modify of the title would be set to that the same timer used for editing the Body of the post. Which is great idea.
And also thought it would be great, if the creator of a thread had the ability, to came back, and check a box .. that would append [SOLVED] to the end of the threads title.
geposted Mon 08 Mar 21 @ 5:02 pm
