there is some way to change the color of the decks using denon prime 4. i can only change the color on the skin
geposted Wed 10 Mar 21 @ 4:05 pm
Look in the mapper, under LED_DECK in main mapper
Not 100% sure, dont have the controller at hand (since it also has left&right wheel display mapper)
But give it a try.. easy to revert back if not ;-)
And I'm sure one of the mapper guys will chip in if its more required ;-)
geposted Wed 10 Mar 21 @ 4:08 pm
Thanks for your help. it worked but you have to change other commands
geposted Wed 10 Mar 21 @ 8:16 pm
could you list what you did as i cannot seem to change the led on the jog wheel when it plays
geposted Mon 08 Nov 21 @ 9:10 am
