What is the name of the jog part Which is used to slow down and speed up the song
geposted Fri 12 Mar 21 @ 9:32 am
No need to post the question twice
I don't think there is a defined name
Some people call it the "ring" or "jogwheel ring" or the "outer ring"
geposted Fri 12 Mar 21 @ 10:37 am
What name is Action?
geposted Fri 12 Mar 21 @ 10:50 am
On a physical jogwheel (using a controller) usually the top surface is used for scratching/cueing, and the edge or rim is used for nudging tempo slightly.
On a skin, you don't have those two separate parts.
geposted Fri 12 Mar 21 @ 11:15 am
And it can't be done?
geposted Fri 12 Mar 21 @ 12:06 pm
What doing tempo slightly.
geposted Fri 12 Mar 21 @ 12:09 pm
Many "nicknames" for it, often just nudge or bend (the song) .. if its just the outer rim.
If its the whole jogwheel, its often called "cd mode" (in contrast to "vinyl mode" that scratches)
For whole jogwheel, the action would be : vinyl_mode (on and off)
For nudging or bending the action would be : nudge or pitch_bend
http://www.virtualdj.com/wiki/VDJscript_verbs_v8.html (look under "audio scratch")
Typically for a skin though you'd use the <scratch> xml element, and have a button to change between nudge/pitch (cd mode) and scratch (vinyl mode)
https://www.virtualdj.com/wiki/Skin%20scratch.html
<scratch>
<pos x="" y=""/>
<size width="" height=""/>
</scratch>
<scratch>
<pos x="" y=""/>
</scratch>
geposted Fri 12 Mar 21 @ 12:45 pm
