Hey there,
I'm new here, just downloaded the software and it does look amazing.
I'm using MacBook Pro 2017 with macOS BigSur and kinda trying to play some music from Apple Music. I have 2 songs saved on my PC, size of both is fine (9 and 14 mb accordingly). Durations are also fine, according to the Get Info.
But in the VirtualDJ it's said that both songs have 00:00 Length and all I can hear playing them is just 1-2 seconds long noise and that's it. Any suggestions?
Dunno how to attach screenshots, will try in the 2nd message. Thanks
geposted Sat 13 Mar 21 @ 11:16 am
apple music, you actually own these tracks? [not monthly subscription]
geposted Sat 13 Mar 21 @ 11:19 am
scr from the VirtualDJ
https://snipboard.io/j9CqiJ.jpg
and from the laptop
https://snipboard.io/C28HhV.jpg
and from the laptop
Not really, it's a monthly subscription. Is it an issue?
geposted Sat 13 Mar 21 @ 11:20 am
If you want to use a subscription service, you have to use one of the subscriptions supported by VirtualDJ
https://www.virtualdj.com/manuals/virtualdj/interface/database/onlinemusic.html
Apple Music subscription cannot be used outside of iTunes.
geposted Sat 13 Mar 21 @ 11:23 am
Yes. The subscription based musuc from Apple is not useable in any DJ software
Only the tracks you actually buy
geposted Sat 13 Mar 21 @ 1:51 pm
