How to specify the color for vocals in next track of single deck automix ?
https://imgur.com/a/eRA2nCI
tested color3/4/5/6 colorvocal= in <down> <off> <on> ... without any success
as beat does not appear either many time the area is black
of course without <selected> no specific color is needed, it takes same colors as playing track
geposted Mon 15 Mar 21 @ 6:06 am
<scratchwave deck="" orientation="horizontal" color="scratch1" color2="scratch2" colorVocal="" colorInstru="" colorBeat="" colorNoVocal="" colorNoInstru="" colorNoBeat="" >
Maybe its not supported for deck=automix - haven't checked. But looks like you're using the correct code.
geposted Mon 15 Mar 21 @ 2:45 pm
Thanks yes it works with "<scratchwaves" which does not split when in automix
Really something missing with "<songpos>" in shapes mode (everything working when in colors mode):
Adding a vertical or horizontal gradient to <selected> make a cool effect that apply to the played overlay (on both tracks) but this removes the instru from the "next to play" one making it black again
circular gradient keeps the color correctly instead. "Shape=" and "border=" "radius=" are usable as well however they only display top half in both areas
geposted Mon 15 Mar 21 @ 5:21 pm
