Hi all.
I have a quetionm I used Vdj 7 and when I recorded a mix Channel Volume was fine .
But I Installed the laste Version 2021 and when I mixing sets, the channel volume is too loud.
I changed DB -3, and still the volume of tracks and chanels are too high. Do have someone the same problem?
geposted Mon 15 Mar 21 @ 2:19 pm
Try to set zeroDB to a lower value (from VirtualDJ Settings->OPTIONS tab)
With -3, you were getting a bit lower recording output, right ? Or had no affect ?
Your Audio Setup in VirtualDJ is just Master & Headphones ?
Also make sure setting autoGain is set to Auto
geposted Mon 15 Mar 21 @ 6:11 pm
Has effect, but if I mixed two tracks together and when I switch te basses, the transition is too loud
I don´t know where is a mistake, when I used VDJ 7, it was fine.
Your Audio Setup in VirtualDJ is just Master & Headphones ? yes and XDJ Aero from Pioneer.
autoGain: set to Auto+ Remember
geposted Mon 15 Mar 21 @ 7:43 pm
![](/img/332061/63316/vdj old setup.png)
![](/img/332062/28604/vdj old sound.png)
![](/img/332063/96367/vdj new setup.png)
![](/img/332064/32050/vdj new sound.png)
geposted Tue 16 Mar 21 @ 8:44 am
In VirtualDJ 8 (2021), try
autoGain to Auto not Auto+Remember.
gainSlidersIncludeAutoGain to Yes
crossfadercurve to Smooth
Re-analyze a few tracks, load, mix, record and check again
geposted Tue 16 Mar 21 @ 9:26 am
Hi djDad.
I try it. But the sound is not good. Could be problem with EQ in VDJ2021?
The setings are same in VDJ7 as I sent and in VDJ2021 I did it as you recommand.
Thank you for your time and answer.
Where could be an error?
Link with 2 tracks transition in VDJ7 and VDJ 2021
https://we.tl/t-qmKnykvYYN
geposted Tue 16 Mar 21 @ 5:10 pm
The vdj 2021 sounds better to me. It's a little bit more quiet, I guess because you have zeroDb to -3dB.
geposted Wed 17 Mar 21 @ 6:08 am
