Many locations do not have WiFi or their WiFI has a secure/protected password. Can the Remote ap still connect to Virtual DJ? If, Yes.. how?
geposted Wed 17 Mar 21 @ 10:29 pm
Yes, you can make a local wifi hotspot... (ad-hoc network, or direct to phone).
Can even connect via usb or bluetooth (hotspot/tethering on the tablet/phone with the Remote app)
![](/img/332173/61767/04bKyCFYrygxqBwHBwYmqUT-33.fit_lim.size_1050x.png)
geposted Wed 17 Mar 21 @ 10:40 pm
So, this will work with a phone, but not a Tablet, unless the tablet has a phone carrier service... yes?
geposted Thu 18 Mar 21 @ 1:16 am
There is no need of carrier service at all, this will work with a tablet without any problem
In a way to prevent VDJ to use your Operator network you may do the opposite:
It's weird but Windows 10 does not allow hotspot when no internet access
third part hotspots are available and work great to share WIFI / BT... even without internet
In every case the more difficult is when remote app is running on a phone without network access
any system tend to disconnect from WIFI "to look for a better connection"
use of WIFI in "plane mode" can help to stay connected
with a tablet there are less issues
geposted Thu 18 Mar 21 @ 1:21 am
Will work fine, hotspot will work regardless ... both from your Android/iOS tablet and phone with the Remote app
geposted Thu 18 Mar 21 @ 2:42 am
Like Rune says it will still work, because it's still wifi based
So a phone carrier service isn't needed
geposted Thu 18 Mar 21 @ 5:37 am
