Hello, I'm using a DDJ200 and when I switch pads pages via key-bindings (from the keyboard ) the controller seem to not get refreshed. Meaning the pads still remain stuck on the first pad that I used. Is there any fix for this?
geposted Thu 18 Mar 21 @ 11:03 pm
is a per deck issue?
what do your keybind scripts look like?
geposted Thu 18 Mar 21 @ 11:48 pm
Should work fine. Did it change in software?
geposted Fri 19 Mar 21 @ 10:37 am
Hello. My script is the following (binded to keyboard keys 1-4):
pad_page 1
Yes, it is a per deck issue, and yes, it changes correctly inside the software.
pad_page 1
geposted Fri 19 Mar 21 @ 11:50 am
change to this
deck all pad_page 1
deck all pad_page 1
geposted Fri 19 Mar 21 @ 12:16 pm
Since the controller doesnt have its own Pad mode buttons, set padSkinindependent to Yes (from VDJ Settings->OPTIONS).
geposted Fri 19 Mar 21 @ 12:20 pm
Okay, but when using the mouse the controller refreshes its pads. I was thinking that using the key-bindings does the same action.
After setting padSkinindependent to Yes, my key-bindings aren't working anymore.
geposted Fri 19 Mar 21 @ 12:30 pm
Ok, we see. We ll' try to provide a solution in next update.
For now, put the setting back to No and use the skin to change modes.
geposted Fri 19 Mar 21 @ 12:41 pm
Great, thank you for the support!
geposted Fri 19 Mar 21 @ 12:54 pm
