Topic: Sound effects
Hi Guys can anyone tell me how to assign a sound effect to the pads on a Newmark MT PRO 3 thanks for any advise
geposted Mon 22 Mar 21 @ 3:33 pm
I have just looked at the manual for your controller and all the information is in there too much to type here I thought I would let you Know.
Just select the ones you want to change.. .
Loop or sample ... if you search in the mapper they show up
Or better, change the mapper to be pad 1, pad 2 , pad 3 etc.. instead of loop 1, loop 4, loop 8 etc.
That way you can use what ever pads you select from the skin..
Just from a quick glance, i dont have this controller, so might be some other challenges but seems like its quite simple names and features to remap
