Hey folks, i have and i5 with 6 gig of ram running 2021 and it's running, but the waves are looking like its running clunky.sounds ok , the waves just look like they are click click click clicking along....do i disable the math engine?.Help.
geposted Mon 22 Mar 21 @ 7:52 pm
might be something else, but you can always try ...
set mathengine disabled and see if that changes anything
And is it only waveform "animation" or jogwheels etc as well? if so check if you changed SkinFPS to really low in settings
geposted Mon 22 Mar 21 @ 8:02 pm
mathengine seemed to do the trick skinfps is at 30
geposted Mon 22 Mar 21 @ 8:06 pm
also seems the 2018 version has never went away was i supposed to delete it , usually it runs right over it when doing an update?
geposted Mon 22 Mar 21 @ 8:07 pm
Perhaps only during song load then?
Its probably purely cosmetic, but still ...
geposted Mon 22 Mar 21 @ 8:08 pm
Can keep it,or delete...
The 2018 version is probably 32-bit (in /programs x86/ )
And the 2021 version 64-but (in /programs/ )
If you do delete 2018, make sure to click "NO" at removing database, playlists etc that pops up when you uninstall ;-)
geposted Mon 22 Mar 21 @ 8:09 pm
Thanks man! i'll probably just keep it for now, since it shouldn't hurt anything..
geposted Mon 22 Mar 21 @ 8:10 pm
Totally fine to keep ;-)
And uses same database etc, so quite seamless to use both ..
geposted Mon 22 Mar 21 @ 8:12 pm
