Topic: Videos Pixlated
anyone know why the videos are pixlated see screenshot
and not pixlated in media player
geposted Tue 23 Mar 21 @ 10:30 am
What type/format of video file?
and in VirtualDJ settings is videoUseDXVA set tp "yes"?
Just for testing, you can also try useLowPowerGPU to "high power" to see if it makes a different
geposted Tue 23 Mar 21 @ 1:30 pm
NicotuxHome userMember since 2014
as well as videoResampleQuality to high and videoMicroFrames ...
also note the screen ratio is not the same, setting letterboxing seems to be set to zoom try bars or crop
or try to resize to fit ratio
the resize introduce some pixelisation
geposted Tue 23 Mar 21 @ 1:47 pm
hi mate yes both are set to what you mention and VOB
doesn't make a difference on resize it's still pixlated, even if i pick bars/crop or zoom
my video settings
this is the file properties info
geposted Tue 23 Mar 21 @ 2:03 pm
any help? isn' this what the forum is for?
all videos are the same pixlated
geposted Fri 26 Mar 21 @ 1:23 pm
Set videoResampleQuality to Medium
geposted Fri 26 Mar 21 @ 2:00 pm
still same mate
geposted Fri 26 Mar 21 @ 3:07 pm
