Hi folks, Just giving my gear a warm up after a 15 month lay off. When I last used it, it was fine on all four channels to my PA. However there have been a few updates during this time and when I connected the controller only decks 1 and 2 are working! How do I get my PC to send a 4 channel signal to my American Audio controller? The ASIO mapping seems ok, but the ASIO driver shows 4, 2 out and 2 in and I can't seem to update it...... HELP!
I'm using Virtual DJ 2020 Infinity Pro and American Audio VMS4.1
geposted Sat 27 Mar 21 @ 12:45 pm
Make sure you have the correct audio settings.. or clickc the VMS button
https://www.virtualdj.com/manuals/hardware/americanaudio/vms4/installation.html
That should sort it ;-)
![](https://www.virtualdj.com/image/68543/195327/Audio%20tab.png)
If not, take a look here:
https://www.virtualdj.com/manuals/hardware/americanaudio/vms4/advanced/midilogs.html
geposted Sat 27 Mar 21 @ 12:56 pm
