When loading a selected FX to the controller, the FX automatically goes to 100%, even when the FX knobs are off. For example if I selected reverb it would automatically go to the max, the same with echo and filters. Does anyone know how to fix this? Cheers
geposted Sun 28 Mar 21 @ 10:39 pm
I guess you mean the default position of the effect?
And 2nd time you select the effect, its at the position you used last?
geposted Sun 28 Mar 21 @ 10:44 pm
