Topic: VIRTUAL PRO LICENCE
Hi everyone,
I would like to know if it possible with the one Virtual pro licence to play on 2 difference PC's at the SAME TIME by the owner of the licence.
Thank you!
geposted Mon 29 Mar 21 @ 9:55 am
Ob es zulässig ist kann ich nicht sagen, aber es geht bei mir.
geposted Mon 29 Mar 21 @ 10:29 am
dj master john 1 wrote :
Hi everyone,
Thank you!
Yes the license allows you to use up to 2 computers at same time (main & backup), as long as its you using it.. ;-)
geposted Mon 29 Mar 21 @ 11:10 am
Hi everyone,
Thank you!
Thanks for the quick respond. Have a good day :)
geposted Mon 29 Mar 21 @ 11:40 am
Vielen Dank
geposted Mon 29 Mar 21 @ 11:42 am
