After many years of using this program I never new the search playlist feature existed. Now that I know about there is 1 question I have. The songs come up multiple times
_LI.jpg)
All the song I search come up like this. Always 3 regardless if they are in playlists or virtual folders.
Thanks
Joe
_LI.jpg)
Thanks
Joe
geposted Mon 29 Mar 21 @ 9:37 pm
Sort the playlist by song name...
By the looks of it you might have songs in the list 3 times.. . At least in the short view in the screenshot some of the songs seem to appear more than once
can for example happen if you have backups that are connected with exactly same content etc
geposted Mon 29 Mar 21 @ 9:50 pm
The songs that look like multiples are different versions. Even if I remove the song out of the virtual folder temporarily it still shows 3 time like its still in there. I'm sure there is only 1 version. All my music is on an internal. Im sure my back up has been plugged in but currently it is not.
Joe
Joe
geposted Mon 29 Mar 21 @ 10:28 pm
Could it be you have 3 copies of that playlist then perhaps?
geposted Mon 29 Mar 21 @ 10:49 pm
I don't think so. At least I cannot see them in the program.
geposted Tue 30 Mar 21 @ 1:42 pm
Tried with several files and it's working correctly for me. Looks like you need to go digging.
geposted Tue 30 Mar 21 @ 2:38 pm
So I went digging and found that it seems songs that were coming up as missing in the history files (of which I had a bunch). I am slowly relocating those files and the problem seems to be sorting itself at slowly. Not sure why it would appear like I had 3 virtual folders but when I went back to the specific song from the pic after relocating them in history file it was fixed. Slow process but works for me. I did have to restart VDJ to see the changes.
Thanks for the help
Joe
Thanks for the help
Joe
geposted Wed 31 Mar 21 @ 5:28 pm
I think you found a bug (or at least a flaw).
Surely if the files are flagged as missing in the history lists, then they should also show as missing in the 'search playlists' results.
geposted Wed 31 Mar 21 @ 8:48 pm
Was just about to post exactly the same thing.
geposted Wed 31 Mar 21 @ 9:54 pm
how to search playlist??
geposted Sat 18 Dec 21 @ 9:19 pm
i too, would like to know this. anyone? thanks.
geposted Mon 27 Dec 21 @ 1:17 pm
https://www.virtualdj.com/manuals/virtualdj/interface/browser/fileinfo.html
Last Play or Playcount can be clicked to look up which playlists contain a specific song.
You can also use a custom button or keyboard shortcut mapped to search_playlists
If you meant to search for a playlist by its name, you can map it to search_folder
geposted Mon 27 Dec 21 @ 1:20 pm
Thanks for the help
Joe
Thanks for the help
Joe
Any more on this issue? As i am getting the same problems with the search folder displaying the same folder twice in vdj2024
geposted Tue 18 Jun 24 @ 10:25 am
There is a couple of issues with Search_Playlists, one is that it's quite inaccurate, sometimes never finding the playlist and the second in that you can't read the full Playlsit title, if you resize the window it crashes the browser and freezes the player. Happens in 2024 and several skins. i didn't go out of my way to test them, was simply looking for a skin you could successfully resize the search window. No luck.
geposted Tue 07 Jan 25 @ 10:23 am
No issues here, have tested on b8490 and it displays all lists and the window can be expanded without crashing.
Would be nice if VDJ allowed you to select the separation level between the sides and remembered the window size however.
geposted Tue 07 Jan 25 @ 10:52 am
Not happening here with default skin on Windows 11 with NVIDIA card, build 8497.
geposted Tue 07 Jan 25 @ 10:56 am
Since update 2025, the function „search playlist“ does‘t Show the tracks in „my lists“. Has anyone a solution?
geposted Sat 15 Feb 25 @ 3:29 pm
Right Click a CUSTOM empty button Name it and in the code box put Search_Playlists. The track highlighted will be searched for.
geposted Tue 18 Mar 25 @ 12:21 pm
