Topic: Numark ns7 mkii
##- Please type your reply above this line -##
Your request has been updated. To add additional comments, reply to this email.
Adrocket
3 Apr 2021, 21:29 EEST
1 am so frustrated I've spent 60 hrs straight trying to make this work,I've downloaded virtual DJ about 10 times,I turn the numark on open vdj plug usb between both,it makes the beeping connection sound but no controls / crossfader or anything works with vdj I don't know what else to do ,it's spoilt my whole weekend and plans I feel sad and am out of options..please help
Get Outlook for Android
Adrocket
3 Apr 2021, 07:43 EEST
Also if I delete virtual DJ and then try to re-download again will I lose all my music in it?
Adrocket
3 Apr 2021, 07:32 EEST
Also I had a pro licence vdj that came with my reloop touch 15 mths ago does that mean I didn't need to buy the pro licence I just bought for the Numark?
Adrocket
3 Apr 2021, 07:30 EEST
I did download virtual DJ from the pioneer site 3 times but when I connect USB to controller it makes beeping sound to Indicate connection but it doesn't work ,the Numark isn't reading vdj??
Ralf (VirtualDJ)
2 Apr 2021, 11:02 EEST
Hi,
it is not longer a license key needed, because everything is now account related.
So please just download VirtualDJ from here and enter your accountname and password. That's it :-)
http://www.virtualdj.com/download/index.html
Please have a look here too.
http://www.virtualdj.com/images/pdf/VirtualDJ8_Getting_Started.pdf
http://www.virtualdj.com/forums/187806/VirtualDJ_8_bug-report_Forum/Virtual_DJ_8_-_Login_and_License.html?search=login&page=1
Now please setup everything as explained here:
http://www.virtualdj.com/manuals/hardware/numark/ns7ii.html
Kind regards
VirtualDJ Support Team
ATOMIX PRODUCTIONS
Adrocket
2 Apr 2021, 09:49 EEST
I bought a second hand numarkns7mkii and a pro virtual dj licence downloaded all necessary drivers and firmware but cannot get to work and have tried everything????
Submitted from: https://www.virtualdj.com/help/
This email is a service from VirtualDJ. Delivered by Zendesk
[8DWEQ8-2ZPO]
geposted Sat 03 Apr 21 @ 6:48 pm
Numark NS7, Macbook Pro 2020 Big Sur, VDJ 8.5. It pop up the message hardware detected Numark NS7 - select where your speakers are connected. Gives me the option for Computer and NS7 but does not allows me to click on NS7. If i select computer it opens the VDJ but the NS7 is not recognized. Do I have to use an older version of VDJ for the NS7? Do I have to downgrade the macOS to Catalina o Mojave? Please let me know. Thanks
